Can't get it to start... the application that is
shippman
Post by shippman »
Just downloaded the very latest TunerPro RT app. First, it wouldn't start because it couldn't find the API-MS-WIN-CRT-STDIO-L1-1-0.dll on the computer. I downloaded the dll to the laptop. It now says it can't start because of error 0xc000007b.
Presently running Windows8.1.
Can you help?
Mielk1jd
Post by Mielk1jd »
I have also tried to install TunerPro onto my desktop, which is currently running Windows 8.1 and I received the same message.
"This program cant start because api-ms-win-crt_stdio-l1-1-0.dll is missing from your computer. Try reinstalling the program to fix this problem."
The api-ms-win-crt_stdio-l1-1-0.dll appears to be part of the Visual C++ Redistributable for Visual Studio 2015. See here for the update:
https://support.microsoft.com/en-us/hel ... in-windows
Correct. Install this one, specifically:
https://www.microsoft.com/en-us/downloa ... x?id=52685
You may also need to check for Windows updates after you install the above.
I'll fix this issue in the next release.
The latest version now requires the Visual Studio 2017 redist. The TunerPro installer should automatically install it, but some folks still seem to be seeing issues. You can manually download and install it from here:
https://go.microsoft.com/fwlink/?LinkId=746572
Then run Windows Update, reboot, and try launching TunerPro again.
Joshua-G
Post by Joshua-G »
i am having this same issue as well and have done everything suggested and i still get the same error code. any suggestions? running a computer with windows vista. Any help is appreciated.
donaldregal1
Re: Can't get it to start... the application that is
Post by donaldregal1 »
Hi ,
Surely I am here to help you.
Follow these steps.
Firstly check your windows whether it”s updated or not
If Windows is updated and everything looks fine, try re-installing the particular program that is reverting https://dll.one/how-to-fix-api-ms-win-c ... ing-error/
Repair installed Visual C++ 2015 Redistributable package
if you already have the Visual C++ 2015 Redistributable package installed on your computer and still getting the error, there’s a high chance that it can be fixed by repairing the program.
Install Microsoft Visual C++ Redistributable Update.
Register the DLL file:
Copy-paste the api-ms-win-crt-runtime-l1-1-0.dll file
Next, plug the drive on your computer and copy that file and head over to C:\Windows\System32\downlevel and paste it there, and that’s it.
Hope your problem get solved by following these steps.
Donald Regal Toss
