Motronic Axis Calculation
crazyf1
Post by crazyf1 » Sun Dec 04, 2011 5:38 am
Hi Mangus,
I am using your example for Motronic Axis Calculation and I saw a bug.
http://www.tunerpro.net/examples.htm
For Example with a RPM axis:
When the axis is created and values converted to RPM, I can modify the maximum RPM and lower RPM will be updated correctly but if I modify and intermediate value, when I commit changes this value and all values below will take a wrong value.
When the axis is not converted to RPM, it is working fine.
Thus, I have to do modifications on an axis not converted to avoid mistake and deal with 2 parameters for the same axis.
Is it possible to have a correction in next release?
