ostrich 2.0 hit tracing latest version do not work
bernhard
Post by bernhard »
hittracing don't work with 8369 and ostrich 2.0 / bosch digifant 1.
with 8202 and 8144 it works.
with the 8369 version the ostrich ist recognized, load up/ down a .bin into the ostrich works, too.
but in tracing modus it still remains on
waiting
... but no jumping yellow cursor will appear.
i thought first, this is an hardware bug and i wasted about 10l of e85, until i tried the elder versions :roll: :D
would you please so kind to check it?
with best regards
bernhard
I will check.
Thank you for reporting this, Bernhard. I've found and fixed the issue for the next build, due out in a couple of days.
I apologize for the inconvenience.
Build is now available.
Matrix
Post by Matrix »
Mangus wrote:Build is now available.
I'am a bit confused.
Download TunerPro RT says
Current Version: 5.00.8383 - Download (3.45 MB)
Release Date: 4/30/13
but Latest version history says
5.00.8393.00 (General Release) (4/30/14)
I think you stayed up too late coding Mark! :D
Just a typo, which has been fixed.
jok
Post by jok »
I also use an Ostrich 2.0 but with a Bosch Motronic on a BMW E30 and I've the same problem with any version of Tuner pro (8369, 8802 or 8144)
I've tried with two different laptop...and no hit tracing (no yellow highlight...), just the "waiting" message:
What is the issue?
Thanks and well done for your work ;)
Different ECUs, and different maps within ECUs, have different access patterns. Some of them are more conducive than others for having their patterns captured by the hardware (and software). Down the road, I may experiment with alternate means of acquiring this data form the hardware, but even so, the Ostrich doesn't see everything.
jok
Post by jok »
Thank you for your help!!
Ok but....it's working in these vidéos, with Ostrich and Motronic 1.3 like me:
https://www.youtube.com/watch?v=Fi_cQODTO8c
or
https://www.youtube.com/watch?v=3SLrK_3KgMU
jok
Post by jok »
No idea?
I read something about ADL, should I have one?
Thank you
jok
Post by jok »
Help please....
Thx
XantheFIN
Post by XantheFIN »
jok wrote:Hello,
Help please....
Thx
Hi jok,
I am not anything familiar what you are doing but i'll try help by advising for what i can find.
First of all.. you have different problem than who started this thread because yours simply won't work on any TunerPRO version?
Little thing; Do you have stock bin or are you trying without it?
What ROM chip is used in this ECU? Say what is written top of it for example.
I found this if it helps you.
