"Error - One or more checksums could not be updated. &q
InfernalVortex
Post by InfernalVortex » Sat Dec 30, 2017 2:06 pm
In TunerPro it continuously gives me this error on any and all bin saves. I can open up a virgin, untampered bin, and save it in a different folder making zero changes and it gives me this error.
It's a laptop with Windows 7 Home PRemium. 64 bit. Core i5, intel graphics or something I think.
The same xdf and bins from the same disc save perfectly fine on a different desktop computer, but I need it to work.
This is with 5.00.8853.00
I tried to use 5.00.9130 but it doesn't install at all.
This laptop works perfectly fine for all the other things I use it for. It's not especially old or damaged. Im at a loss, but it seems like a hardware issue but Im not sure what I can do to fix it.
InfernalVortex
Post by InfernalVortex » Sun Dec 31, 2017 7:31 am
It appears version 4 doesn't have this problem. Only version 5.
Fierobsessed
Post by Fierobsessed » Sat Jan 06, 2018 11:14 am
Looks like an issue I'm still having too.
http://forum.tunerpro.net/viewtopic.php?t=4012
Try just simply reloading the XDF then re-save the bin. If it doesn't give you trouble then yours is giving you the same problem I have. It has persisted from 5.00.8853 into 5.00.9107
88' Fiero GT 3.4 DOHC F40 6 speed GT3582R running on $8F.
Fierobsessed
Post by Fierobsessed » Thu Jan 11, 2018 3:18 pm
Found a workaround. It seems like if the Definition (XDF) is in the same folder as the tune (BIN) this issue shows up. Create a new folder and put the definition (XDF) in there and the issue goes away.
