Crashing
Foolee
Crashing
Post by Foolee »
If I try to import a definition file from EEC Editor it crashes the program cauing it to close. I tried to import stategy REAC4.def
http://support.moates.net/ford-strategies-supported/
The crashing is most likely a sign of an error message not being handled correctly (I suspect it is probably a failure to report an attempt to import an unsupported format is being attempted). TunerPro will only import .ecu and .csv definition files for conversion to a .xdf file.
