Potential XDF editor. Parameter Low/High range issue
mourat
Post by mourat » Tue Apr 09, 2019 6:03 pm
I'm new to Tunerpro. Having had access to the program for over 10 years, I finally started to understand how powerful it is.
I started by playing with XDF files, and created one for a 2004 C5 Corvette P59.
My issue is that when I go into the XDF editor, and I set the minimum / max value. (check box selected) for temperature where I want the value to range from -40 to 140. It appears that the range defaults to 0.
I assume I'm doing something wrong? Or is this perhaps a bug in the newest version of TunerPro?
Figured out the minimum value. After hours of searching, as soon as I posted it of course!
Acki
Re: Potential XDF editor. Parameter Low/High range issue
Post by Acki » Fri May 10, 2019 7:00 am
Wrong / non conversion factor.
When you use the values "direct" then is 0 the smallest possible input.
Run is this failure years ago when I used to limit the maximum in a fuel table - unfortunately TP doesn't shows you when you run into this limit.
You raise or lower the value, you save it and nothing happens (even the shown value doesn't change) - reopen of the scalar/table shows you the lower limit.
