Logging & Playback
Locked
moonwell
Logging & Playback
Post by moonwell » Sat Oct 21, 2006 1:45 pm
Just saw the beta was out & downloaded today. I ran an import on my $A1
.ads file and created a dash. Just tried logging the car in the garage and all
the values were just fluxuating all over the place. Speed kept jumping from
0 to max, RPM bouncing, etc.
So I saved the log & tried to play it back. On the playback screen, the data
won't update unless you hit play, pause, play, pause. This data shows on
the dash, but the items list screen always stays at 0.
Think this is an issue with something in my .adx, or something else? I tried
running the log playback on both my laptop & desktop machines running XP.
Sil
Post by Sil » Sat Oct 21, 2006 2:19 pm
wierd, might be your connection macro...post up your adx file
moonwell
Post by moonwell » Sat Oct 21, 2006 2:57 pm
Here is an ADX
http://www.v6z24.com/misc/tuning/A1-Wid ... test09.adx
Does somebody have a .xdl log file that they have recorded under one of the code masks provided with the beta so I could see if it will play that correctly on my machine?
moonwell
Post by moonwell » Sat Oct 21, 2006 3:39 pm
Alright, by checking the RS232 Echo box, I got it to show up correctly real-time, but my log playback is still screwed up and the playback doesn't even show the same data that I saw when I was logging.
moonwell
Post by moonwell » Sun Oct 22, 2006 8:39 pm
Looks like the current build fixed this playback issue. :) Thanks!
Locked
