First post
916 RS
First post
Post by 916 RS »
For other motorcycles we can do a lot with Tuner Pro.
I only tune Italian bikes.
For all the eprom bikes like some Aprilia and MV there is a solution.
For the OBD bikes you can use Tuner Pro also.
But for this we need a OBD flasher.
But this also works.
So if there are any things to discuss lets go.
MV, Gilera, Aprilia,Piaggio,Moto Guzzi, Moto Morini and even
Ducati.
Can help with some XDF.
Need only the bin for exactly the bike for that it is.
ChicagoRob
Re: First post
Post by ChicagoRob »
916 RS wrote:For other motorcycles we can do a lot with Tuner Pro.
Ducati.
Hey 916.
Do you think that you can help me out with an XDF for my 06 ST3s Duc? I have a bin but I'm a total noob.
Rob
Scra99tch
Post by Scra99tch »
Hey RS,
Would you be able to help me on some of my mapping? I have a guzzi quota 1100es and it is getting horrible gas mileage.
I am typing on an iPad and but can explain a little more on what I have tried on my maps
jim
916 RS
Post by 916 RS »
Hi Jim.
it`s 15M ECU :?:
Therefore I need a bin to write XDF.
If you have already one , first began with
synchronisation, idle and CO settings.
highflyer
Post by highflyer »
Hi RS,
I would like some help with the XDF files for two IAW15Ms .
One is from my 900SS , mapped with the Technoresearch software and the other from a spare bare pcb off a Monster 900 .
May I PM you the bins ?
Angelo
916 RS
Post by 916 RS »
Hi Angelo,
you can do that.
Will take a look at it.
Axel
Scra99tch
Post by Scra99tch »
Wow sorry RS, did not realize I posted so long ago. Thats what having a baby will do to you plus a very long cold winter.
Anyways I did a adjustment on my balance and CO settings but that did not seem to help. Comparing to other maps (all IAW15M) my acceleration enrichment is way up and my engine temp trim is different.
Anyway to send the bin to you that I am looking at?
shrubba
Re: First post
Post by shrubba »
Ducati.
Hi,
I own an Aprilia ETV 1000 with Sagem MC1000 ECU.
For editing fuel maps, ignition maps and for doing
some maintenance work there is a software called TuneEcu.
Unfortunately, that software gives no access to any
fuel correction table, e.g. engine temperature, air temperature,
air pressure, ...
Since the engine is getting too lean with increasing
engine and air temperatures I need to have access to these
correction tables.
To make long story short: Does anyone out there have an
XDF for the Sagem ECU?
As far as I know, the MC1000 has also been used on Triumph
and MuZ bikes.
Oder direkt an Dich, 916 RS: Kannst Du evtl. aus einer
aus der ECU extrahierten BIN-Datei eine XDF erzeugen?
Greetz, Mathias
