Filter for min/max values in History tables
Matrix
Post by Matrix » Sun Feb 23, 2014 5:25 pm
I would like to see a feature added that sets the range of acceptable values for the history tables. This way, if you are looking at Injector pulse width, you can filter out when you are slowing down and the ECU fuel cut logic cuts the pulse width to zero.
EagleMark
Post by EagleMark » Tue Mar 18, 2014 8:59 pm
Filters would be awesome! :)
JP86SS
Filters :)
Post by JP86SS » Sat Mar 22, 2014 11:46 am
As an expansion to this idea if it is considered for implementation.
Have the filter value selectable as one of three types.
a.) Numeric value (Integer or floating point)
b.) Data item value (ex: Speed > xx.xx, selectable from ADX list)
c.) Bit driven (ex: TCC = true, Selectable from ADX list)
Ability for any number of these values, stacked as go/no-go parameter for what goes into the data table display.
Jp
vxl67getrag
Update for filter
Post by vxl67getrag » Sun Jul 31, 2016 1:47 pm
Howdy all,
Just wondering if there is any update to this?
I would like to add a TPS filter to history table for closed throttle & open throttle wideband afr error.
The1
Post by The1 » Mon Jun 26, 2017 6:11 pm
just checking up on this also, would be a nice feature to have, would help me tune different load areas easier
