Hallo,
last year my Ostrich 2.0 works fine.
Today i have put it again in my car. The car does not start.
Ich have put the Ostrich 2.0 on my EPROM Burner.
When i read the file with the burner from the Ostrich 2.0, it is not the same i have laoded up in TunerPro RT. ??
I save the wrong data form the EPROM burner in a bin file. Than i laod the wrong file in TunerPro RT to the Ostrich. When i read out this file with the EPROM burner, it is matching with the uploaded file in TunerPro RT.
I have testes this on 2 Laptops. Same issue.
What is this? Can anybody help?
Ostich 2.0 emulation - wrong file when verify with EPROM burner??
Re: Ostich 2.0 emulation - wrong file when verify with EPROM burner??
next test:
the EPROM burner reads everytime the same data from the ostrich, it dosent mather what i laod with tunerProRT into the ostrich 2.0.
If i press "verify" in TunerPro RT -> sucsess.
For TunerProRT the data is in the Ostrich - but the EPROM Burner reads out always the same wrong data.
i have solved the problem:
-may be i have change position of the switches
or this:
http://support.moates.net/troubleshooting-switches/
-Fortunately, the solution to switch glitching is really easy. Sliding the switch back and forth vigorously 5-10 times has been successful in restoring normal operation.
or this:
