Wide band O2 sensor logging with GUFB.adx
broncomike65
Post by broncomike65 » Wed Nov 05, 2014 6:16 pm
I need a little help configuring the Innovate LC-2 controller with the dash board setup in the GUFB.adx file. I'm not sure the conversion equation listed under the Wbo2 gauge is correct when viewed in the adx editor. The conversion is 7.35 + ( X / 4267)....would this be correct. When the motor is running the reading stays at 7.35.
I have the yellow wire from the Lc-2 sensor connected to the evp sensor pin 27.
EGR is enabled
