Who Needs An ADS or ADX?
TheDougO
Post by TheDougO » Sat Mar 18, 2017 4:34 pm
Robert,
Excellent! It looks like it is reading the data correctly now and not bouncing all over the place. Much thanks on this!
- Doug
robertisaar wrote:https://www.dropbox.com/s/yp7izg144ehoy48/A263.zip?dl=0
that should do it.
jce85
Post by jce85 » Sun Apr 02, 2017 3:08 am
Im looking for a Mefi 4 definition file. Anyone?
Paul Miller
A028 High Speed ADX file request
Post by Paul Miller » Fri Apr 07, 2017 4:33 am
I am currently working with an '87 Camaro with the LB9 series motor and the 1227165 ECM. I have successfully logged data at the 160 baud rate using the 1227165_160.ADX file. As I read the A028 data steam definition it indicates that this particular ECM is known as a "Hybrid" and capable of outputting two speeds: 160/8192 baud. The stream definition lays out two sets of parameters, one set for the low speed stream and it has 25 parameters. There is a second set of parameters, 63 parameter bytes.
1. Where do I go to get the correct ADX file to use for high speed logging?
2. I have scoured the EFI-Gearhead forum and do not see what I think I
need. Could it be as simple as using the 1227165_$6E.ADX file? I have reviewed the spec and ADX file and believe they are similar. Just lacking in knowledge to confidently move forward with a logging effort.
Any assistance is appreciated. Thank you.
Post by robertisaar » Sat Apr 08, 2017 5:30 am
the 6E ADX is very similar to the one that would be correct for your car, there are only a few status bits that are different(going off of memory).
Jeppi94
ECM 1228330 FDX & ADS
Post by Jeppi94 » Tue May 09, 2017 3:07 am
Anybody know where i can find these: ECM 1228330 FDX & ADS for a 89 Cadillac Brougham with the VIN Y LV2 5.0 Olds 307, or perhaps some kind soul could make them?
Cheers!
Esigward
Re: Who Needs An ADS or ADX?
Post by Esigward » Fri Jul 21, 2017 9:57 am
robertisaar wrote:i've got time on my hands and have been slowly adding to the list on the site, but i don't know what people want/need.
I have been searching for ADS + XDF file for $0DA 16196395 or
16197427 94 - 95 Truck, Van, 4.3L L35 CPI. You may not have time now, you posted this some time ago. But any info you may have can help.
T33
Post by T33 » Fri Jul 21, 2017 1:46 pm
It would be nice to have XDF+ADX for 1228706 89-93 3.3l LG7
Stokes1114
Post by Stokes1114 » Sat Jul 22, 2017 2:34 pm
I am looking for a XDF for the $OD MAF code. Specifically one with the 4L60e parameters in it. I have all the other files I believe. I can switch xdfs from the maf one I have to a regular $OD one and can see the trans parameters are in the bin, just not in the maf xdf. If anyone has it please let me know.
hamhock75
Post by hamhock75 » Fri Aug 04, 2017 2:20 am
I could use A263. Can you mention what is needed to create a specific .ads?
Post by robertisaar » Sat Aug 05, 2017 7:41 am
lonewolf41
MEFI 4b
Post by lonewolf41 » Fri Sep 01, 2017 4:47 am
Looking for MEFI 4b. Hoping there is one out there. If not, is there a tutorial on how to create one?
TIA.
silvernblack
Post by silvernblack » Sat Oct 21, 2017 6:32 am
anything available for 1988 Oldsmobile 98 ECM 1228253/1619264
norcalthoroughbred916
Post by norcalthoroughbred916 » Thu Nov 09, 2017 7:35 am
Desperately in need of definition file for a 1991 Buick Century Custom Wagon with the 3.3l v6. Help is greatly appreciated!
ajlal naseem
Post by ajlal naseem » Fri Jan 05, 2018 9:21 pm
I have GM Daewoo Chevrolet Exclusive(M150) 2005, what definitions file do i need ? :?:
sabinoerc
93 5.7 K L05 C1500 suburban
Post by sabinoerc » Fri Jan 12, 2018 9:05 am
Hi
I just rcvd cable from Moates and downloaded TunerPro.
I'm a bit confused on a few items.
Looks like mask id $99 99.ads should work for engine though I have a 4L60E, not a 4L80E.
what would be ads file for the transmission?
also - I see Robert has list of obdi datastream definitions and the A179 appears to be very similar to 99.ads - but not identical.
What is a "datastream file" - ie. A179 vs an .ads file. Are they one and the same?
If there is link or reference to read, I can spend some time before using this groups time. I didn't see one on Google. - seems all links point back here!
Ed
78jazzman
"Retro" needs help.
Post by 78jazzman » Sun Feb 18, 2018 3:58 pm
1994 Oldsmobile 88 LS, 3800 V6 (No turbo)
This car is amazing! I paid $350.00 for it four years ago and put over 40,000 miles on it (Now 205,600). It has been nearly trouble-free.
Check Engine light came on last year and using TunerPro RT, V5.
I used:
$5B 16183247
V5 ONLY -5B_V5.adx
94-95 Series 1 3.8L (L27) and 94-95 Series 3.8L SC (L67)
I was able to diagnose a faulty Throttle Position Sensor. Cheap and easy fix.
I was able to create my own dash and watch the 'gages' as I drove to work. (Actually I recorded the trip and watched it later). It was an easy find and an easy fix.
Now I have the ABS lamp on and am having trouble getting usable data. the values are very unstable.
I am trying to use:
(ABS) 94-95_L_N_ABS.ads 94-95 L and N Body ABS module (only)
Is this the right Datastream Definition?
When I connect, the data is running about 3 - 5Hz and is all over the place. I tried to implement "Wait for Silence" at the beginning of the commands (70-100 ms) and I tried to tweak command replies, but I have no idea what the delays and packet sizes should be set at.
I'm using a Dell M4600 laptop with Windows 7 Pro.(2012 vintage)
So.. do I have the correct ABS definition? And can anyone help me to get this running?
Post by robertisaar » Wed Feb 21, 2018 6:58 am
I'm not at home at the moment, but I know your car isn't a N-body, fairly certain it is a H. Not sure if I've built a definition for it yet or not.
philalbar1
93 S10 Unicorn
Post by philalbar1 » Thu Apr 19, 2018 4:36 pm
I am having some complications finding a bin that gets close to my application, and I was hoping for some guidance. I have a 93 S10 4.3 LB4 engine code that came with a BCFZ memcal chip. I have converted the truck to a 5-speed from a 91, and the engine is going ballistic. I just got my autoprom in the mail today, and was hoping someone could direct me to a NON-California compliant bin file for a 4.3 V6, just to give me a good start. My truck doesn't have EGR or Cats, so you can blame me for the lack of ozone if you like, but I'd really like to dial this truck in. I can do it the hard way if necessary, but I'd really appreciate someone pointing me in the right direction to someone who's already done the leg-work. Thanks in advance!
~Phil
