Cant get CDAN4 def to line up with bin
cstaples
Post by cstaples »
I am having trouble getting the bin to line up with the def with a LLX4 ECU.With Flash n Burn I pulled an EEC V file with address 000000 to 03FFFF and have a 256k file like the def says but the injector and maf info is not right.
cstaples
Post by cstaples »
I did pull a 256k file with the ECU hooked to the car and on the bench and that does make a difference.I can burn the one from the bench and have a CE light.
So it looks like EEC V ECUs need to be hooked up to the car to get a good read.
cstaples
Post by cstaples »
I figured out that when I pulled the bin out of the ECU on the bench and burnt that to the chip the car would run but the CE light was on.When I pull the bin out with the ECU hooked to the car and burn that to the chip it runs fine,no CE light.
Also can someone help me split the file that I pulled out so that I can change some things in it.The CDAN4 def looks like it uses a 112k file and I havent figured out to use the bin splitter to get that file size.
cstaples
Post by cstaples »
After digging thru the def and the bin I came up with these files that some of the paramaters line up but there are some that dont.I also noticed that in the download section the CDAN4 description says it uses a full 256k file but until I changed the file size in the DXF header editor to 40000 and the base offset to 4000 with no subtract nothing lined up at all.
The things I noticed that didnt line up are all of the cooling fan temps and the injector hi and low slopes.
Can someone try to help me finish this def?I dont know how to find things like inj slopes etc.
The way the def was I had found a 112k file on the net that looks like everything lines up but I get a CE light if I use it.
Thought this might help someone.
Right click and save as
http://staplesautoengineering.com/Files ... 20256k.xdf
http://staplesautoengineering.com/Files ... 20Read.bin
cstaples
Post by cstaples »
I did some digging and got the fan temps and the injector slopes figured out so I thought I would post the file for everybody.
The read file is a stock bin in the previous post and this is the new def file for a full 256k read.
Some things might not still be correct but the major stuff like MAF transfer,inj slopes, fan temps,rev limits,etc.
Enjoy
