I went out to scan today and I set up the preferences for my usb ALDL cable to the correct com port, etc etc. Now the first time i tried to log, it got tons and tons of ERRORS at the bottom of the screen. So i stopped it, replugged everything in, and tried again. This time she worked well and seemed to be reading at the usual data rate like tunerpro v4.
However, as i was logging I noticed that the readout would sporadically get garbage data. I'll upload a logfile in a bit just to show you what a mean. basically my little digital dash would show my correct speed then for a split second it would read 255mph and then go back. This is the same for all of my readouts. I'm a member on the Thirdgen.org boards and I believe I've seen mention of this problem there as well, so I'll be reading as much as I can.
Just wondering if this was a common bug and if there was a quick fix! thanks a ton and great work!
