Can't find requested numbers to log
Ophitoxaemia
Post by Ophitoxaemia » Sat Jan 30, 2016 12:18 pm
My tuner has requested these values: MINIMUM, FUEL, IDLE AIR, and MAFV.
I've scoured the Parameter list in Tuner Pro RT but I can't find anything that looks anything like any of the four of those.
I have a custom BIN loaded, the GUFB.xdf XDF file and the GUFB_56k.adx file loaded.
I've also connected the 0-5V output of the AFR meter to pin 27 of my EEC-IV, should be the ecu's EGR valve position input. I imagine this is to log the AFR which gets delivered to the ecu as the EGR position, but I can't find anything that looks like that either in the Parameters list.
I'm following the instructions here: http://tunerpro.net/forum/viewtopic.php?t=2674
Thanks for any ideas which values to log.
Ophitoxaemia
Post by Ophitoxaemia » Sat Jan 30, 2016 5:10 pm
It looks like the "how to" topic I was following was using Parameters to define data acquisition, but that didn't work for me. The Parameters look to be the values that define the tune, and the .adx file is what defines what is logged. So I managed to log a set of plausible looking values anyway.
