using 700r4 with 8051 PCM
ldc7675
PostPosted: Fri Oct 14, 2016 6:28 pm    Post subject: using 700r4 with 8051 PCM Reply with quote
My definition file will be $EEx.
My question is if I use a 4l60 / 700r4 and deselect the 4l60e will the TCC lockup function still work along with the brake switch. Also will I be able to select 3 and 4 gear lockup. I plan on using the tcc control line from the PCM
any suggestions or help will greatly be appreciate.
thanks
Larry
