Searching for XDF 0261200172 and 0261204620
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Bosch
Lambda1
PostPosted: Mon Jun 19, 2017 4:32 am    Post subject: Searching for XDF 0261200172 and 0261204620 Reply with quote
Hi,
searching for a while ...
M20B20 / M20B25 0261200172 xdf file and also xdf for
Bosch ME7.2 0261204620.
If someone can help, please.
Lambda1
PostPosted: Thu Jun 22, 2017 9:17 am    Post subject: Reply with quote
Im willing to pay for it Wink
Hairyscreech
PostPosted: Wed Jun 28, 2017 3:16 am    Post subject: Reply with quote
172 and 173 hardware is the same as far as I am aware, you can use the same chip in either ECU to run either of the corresponding engines.
I have a standard 172 ECU sitting in my office that I could pull the .bin off for you to compare with the 173 .bin.
If the files are the same bar the values in the maps, then why not just tune using the 173 .bin or use the 173 XDF?
A similar situation to the M3.3.1 413 and 506 ECU on the E36.
Lambda1
PostPosted: Thu Jun 29, 2017 12:44 pm    Post subject: Reply with quote
You cant use 172er bin with xdf for 173 ...
Maybe (i dont tested) you can use 173er bin in 172er ecu.
I search for 172 xdf.
Hairyscreech
PostPosted: Sun Jul 16, 2017 11:40 pm    Post subject: Reply with quote
If you are really set on using the 172 bin then your best off making the XDF yourself.
All the maps you need are laid out on the 173 XDF and the corresponding data in the 172 bin will not be too far from the 173 location (simply due to how BMW did the code).
aboutton
PostPosted: Thu Jul 20, 2017 1:48 pm    Post subject: Reply with quote
use 173 bin with 173 xdf in 172 DME
both ECU are identical
_________________
HyperBoost Tuning
Tony Ouneissy
Lebanon
View user's profile Send private message Send e-mail Visit poster's website
Lambda1
PostPosted: Wed Jul 26, 2017 2:06 am    Post subject: Reply with quote
I know this facts ... and I do.
First Time I want to use 172er but it seems nobody have xdf ... so i will create by my one if i had time for it.
But for 0261204620 maybe someone have once?
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Bosch All times are GMT - 9 Hours
