MINPW Zeros Out
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Ford
frankenstang
PostPosted: Sat Aug 26, 2017 12:26 pm    Post subject: MINPW Zeros Out Reply with quote
If I change MINPW to ANY other number other than what is already in the BIN it will zero out. The value is permanently 0.00. Iíve put 1 in and Iíve put 100 in and the value is 0.00 after hitting save. Say for T4M0 the stock value is 1.4 when I change it to the injectorís MINPW and hit save it comes back 0.00. If you open the text file that logs the changes will say 1.4 to 0.00 and 0.00 to 0.00 for every time after that you try to change it. Basically itís broken. Is there a way to fix this?
PostPosted: Tue Aug 29, 2017 7:15 am    Post subject: Reply with quote
This is an intentional feature in the XDF, according to its author.
_________________
frankenstang
PostPosted: Tue Aug 29, 2017 11:04 am    Post subject: Reply with quote
Ok. Thanks
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Ford All times are GMT - 9 Hours
