i am in trouble with my datalogging and I am confused because I can't deduce what's causing it ...
I made 10 logs all in all. The first 5 logs were up to 10 minutes, and I was happy. 2 logs stopped and I assumed this was my fault.
Then I changed the dashboard and had more gauges in and today I went out for a new set of logs.
The first 2 logs are fine, the later ones are with spikes in and the after a short time the loggins stops (about 1 min)
See here:
Anyway, when the logging process stops by the error, the system is NOT halted. The log data is skipped and Tuner Pro RT displays a blank main monitor, but I am able to save the log.
Opening the broken log at home and tracing the log shows this:
I have uploaded a bundle of the related data (xdl, xdf,bin, adx) for playing with it and if anyone would be able to give me an idea how to overcome the problem ...
Thanks a lot ...
Download this Spikes.zip
The system i am doing the logging is an IBM S10-2 netbook, with 1GB of RAM and Intel® Atom™ Processor with 1,66 GHz .
My Virtual Com Port Driver is the latest version
FT2232, FT232B, FT245B, FT8U232AM, FT8U245AM 2.08.02
The Bike is a Buell XB12 with DDFI-3 , MJ 2009.
