Question about L6 ecu
gkoutsis
Post by gkoutsis » Wed Dec 08, 2010 1:43 am
Hi guys, My first post here although I've been reading for quite some time now.
So, I have a 2WD cossie with L6 ecu. We did a first stage program which gave us 262bhp on the dyno. All well.
We now swapped the injectors for the 403 grey ones (506cc), 3bar map and bigger turbo.
However, I am unable to make the injectors work correctly. Which map do I have to change? We don't plan on going more than 1.5 bar.
Thanks in advance for any help :)
gkoutsis
Post by gkoutsis » Wed Dec 08, 2010 2:01 am
Also if I want to completely remove the boost limiter. It now cuts at 1.05 bar and I adjusted the slider to 15psi.
Post by dex » Thu Dec 09, 2010 4:16 am
For your injector change you will need to alter the following:
Fuel Table
WOT Fuel Multiplier
Injector Offset vs Voltage
Cranking Fuel PW vs ECT
There may be other items needing changing too.
gkoutsis
Post by gkoutsis » Thu Dec 09, 2010 5:52 am
I guess I have to reduce the maps.
Any idea how much?
Post by dex » Thu Dec 09, 2010 6:00 am
As a starting point, try the ratio of the injector sizes.
gkoutsis
Post by gkoutsis » Thu Dec 09, 2010 6:02 am
If only I knew where the injector constant is.....
Post by dex » Thu Dec 09, 2010 6:07 am
I don't even know if there is one.
gkoutsis
Post by gkoutsis » Thu Dec 09, 2010 7:23 am
What about the fuel multiplier? What if reduce it to a point where less fuel than stock is sprayed?
Post by dex » Thu Dec 09, 2010 7:33 am
You would clip the new value to a minimum of 1.000
