APU1 Moderated mode
Locked
JP86SS
APU1 Moderated mode
Post by JP86SS » Mon Jun 02, 2008 3:16 pm
Is there a way to use my AP in moderated mode to allow the extra 3 10 bit channels to be logged?
Been poking at this but have not come to a solution.
I'm thinking the comm routine needs a different command string or something to translate the AP. I've only been using it in bypass mode.
Since it works great in TP I figured to ask if this is possible (currently anyway)
TIA
John
Post by Mangus » Tue Jun 17, 2008 6:40 pm
Yeah, for 8192 mode. You have to add the 3 "moderated" bytes to the start of every command, and the appropriate wrapper checksum to the end of the command.
The first 3 bytes are:
'K' + request size (e.g.: 4) + response size (e.g.: 64) + <entire command> + external checksum
Where the external checksum is the 8 bit sum of all bytes, no carry.
Hope that helps! Please let me know if you get it working!
I plan on adding native AutoProm support.
-M
Locked
