ScannerPro with WB02 Device
Locked
desmo01
Post by desmo01 » Sun Aug 17, 2008 9:59 pm
Gents,
Anyone using scannerpro with a wbo2 device?
Might be useful info....
http://www.wbo2.com/sw/logtech.htm
raparici
Post by raparici » Wed Nov 05, 2008 7:27 am
What would be really interesting is to port in ral time the OBD-I loged data to innovate MTS so that all data can be visualised together under logworks.
cheers,
Ruben
Post by Six_Shooter » Wed Nov 05, 2008 9:07 am
raparici wrote:What would be really interesting is to port in ral time the OBD-I loged data to innovate MTS so that all data can be visualised together under logworks.
cheers,
Ruben
Thought about that....
Still seems to be easier to run the WBO2 in through an unused input and patch the bin, along with modifying the ads/adx. This is for the GM ECM anyway, since that's what I'm most familar with.
Besides TP RT/Scanner Pro have many more capabilities than LW2/3, so it would make more sense to import the WBO2 data to these programs. ;)
cbernhardt
Post by cbernhardt » Thu Nov 06, 2008 10:06 am
Six_Shooter wrote:Thought about that....
That is the approach I used. I have a GM Ram Jet 350 crate motor with an MEFI4a controller, also an Innovate LM-1 wideband. I routed one of the analog outputs of the LM-1 to an unused input channel (fuel pressure) on the MEFI4a, changed a few values in ScannerPro, and now I can log the AFR along with the other engine parameters.
Charles
cstaples
Post by cstaples » Mon Nov 24, 2008 1:25 pm
On my 94 LT1 motor I used the AC pressure input to datalog WB.Just have to input the formula for the WB you are using.
Locked
