tunerpro works, scannerpro dont
Locked
The_Punisher454
Post by The_Punisher454 » Mon Sep 15, 2008 12:52 pm
I am currently working with an $83A mask on a 91 S-10. using the $83A ads file from the moates website works fine in tunerpro, but when I convert that definition file to an ADX it is tempermental about connecting and then when it does the data is crap!
I've been messing with this for two days and cant figure out what the problem is.
Post by Six_Shooter » Mon Sep 15, 2008 1:28 pm
I don't think th eimport feature of Scanner Pro works, or at least not the way you would expect.
You really need to start from scratch to get a good Scanner Pro definition.
The_Punisher454
Post by The_Punisher454 » Mon Sep 15, 2008 2:44 pm
okay, I may have fixed it myself. I replayed a 30 minute drive log and started adjusting the packet offset on the vehicle speed value untill it matched reality. which was to add 4 to what it was before. I offset the rest of the values and they all seem okay now too. I thought that was taken care of by the packet offset setting in the command setup? oh well it works now.
The_Punisher454
Post by The_Punisher454 » Mon Sep 15, 2008 2:48 pm
no, the import works, in a way. It allowed me to get the right checksum value in the mode1 command. and it gives you all the aldl values from the ADS file.
You have to import the ADS, save the ADX, and then load the saved ADX in order to even see any values in the editor. I dismissed the import feature for a long time because I thought it was totaly broke, since the editor stayed blank after "importing".
Locked
