adx for Marelli P8 (Lancia, Cossworth, Fiat)
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Other Car/Truck Makes
rob
PostPosted: Mon Jul 19, 2010 8:43 am    Post subject: adx for Marelli P8 (Lancia, Cossworth, Fiat) Reply with quote
Anybody tried to make an adx for Tuner Pro v5 for the Marelli P8 ECU from Lancia Delta or Fiat Coupe 16v?
Back to top
revlimit
PostPosted: Mon Jul 19, 2010 7:18 pm    Post subject: Reply with quote
no
Back to top
rob
PostPosted: Tue Jul 20, 2010 7:18 am    Post subject: Reply with quote
Ok, i started with an adx, 8bit values and lookup tables are working but i have some troubles with 16bit values. Anybody know how to connect two 8bit values from different requests?
To be more clear i have to send 1 to the ecu and get back the MSB for Engine period, then i have to send 2 (literally the value not the number which would be 0x32) and get LSB of Period. How to connect??
BTW i think i found a small bug in v5, i can't enter negative Values in the Lookup Table.
Back to top
PostPosted: Tue Jul 20, 2010 8:26 pm    Post subject: Reply with quote
value 1 (most significant bit) = 8 bit value, equation = x
value 2 (least signifcant bit) = 8 bit value, equation = x
value 3 = 16 bit value, equation = a * 256 + b, where a is output from value 1 and b is the output from value 2.
Give it a shot.
_________________
Back to top
rob
PostPosted: Thu Jul 22, 2010 4:21 am    Post subject: Reply with quote
Ok. Got it so far, works like a charm. But there is one Problem left. TPS Conversion is:
if Degree < 30
Degree = (Data*0.1848)-1.41
else
Degree = (Data*0.7058)-90
How can i implement this??
I figure i can calculate both but how to compare?
Another Question i'd like to share this adx, where can i upload it?
Thanks for all the help and a really great piece of Software.
Back to top
PostPosted: Thu Jul 22, 2010 7:05 am    Post subject: Reply with quote
A near future version of TunerPro will be able to do this. You can send me the ADX, along with the vehicle information that it applies to.
_________________
Back to top
hnracing
PostPosted: Thu Jul 22, 2010 8:54 pm    Post subject: Reply with quote
Use the lockuptable funtion.
Since it is two linear funtions that will do it.
Works for me.
Let me know if you find a solution for the adx conversion of the RPM not to show 229 at standstill.
Back to top
rob
PostPosted: Fri Jul 23, 2010 12:34 am    Post subject: Reply with quote
Thanks, it worked. I don't have a solution for thr RPM issue but my adx says 8000 rpm, which is the max rpm, without data.
I send my adx to mark, i am sure you can download it soon. Maybe you can send him yours too. We can compare results if can get a hold of your adx.
Back to top
Display posts from previous:
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Other Car/Truck Makes All times are GMT - 9 Hours
Page 1 of 1
Jump to:
