Ducati 748 916 996 Bin and XDF File - Can you sort table?
Deckside
Post by Deckside »
I'm new to this so please take it easy on me.
I have found 4 bin files and 1 XDF file to suit 748, 916 and 996.
I have started looking at the files while I await delivery of my EPROM Burner and Chips.
When I look at the files, 2 of the files have the tables nicely sorted in order and the other 2 are not sorted. So when I go to look at them in the 3D graph mode they are impossible to understand.
Am I doing something wrong?
Do I need a different XDF file for each bin file?
To see screen shots follow links below.
Thank you in advance.
http://www.ducati-superbikes.com/forum/ ... ureid=4195
http://www.ducati-superbikes.com/forum/ ... ureid=4194
916 RS
Post by 916 RS »
Hello , i`m new here in this forum.
First : Thank`s Mark for this great program !
I work with the Ducati ECU`s sinse 1990.
Now i write my maps with a sort of autotuneprogram,based
on AFR target .My little program works very well with Tuner Pro.
So i can drive on road or dyno, log AFR, push button and get
the corrected map.
@ Deckside
For all the Ducati bin files you need differrent XDF file.
I can help with all XDF files for P7,P8 and 16M.
Send me your bin and i give you the correct XDF file.
Now i try to write XDF files for 59M and 5AM ECU`s.
In this case i think i need a little help.
Greatings from Germany
Axel
mvilbro
Re: Ducati 748 916 996 Bin and XDF File - Can you sort table
Post by mvilbro »
Hey Deckside,
You shouldn't need different XDF files unless they are for different ECU's.
I did find a similar thing when looking at different .bin files.
Open one that you think doesn't look right, then click on;
XDF\View/Edit XDF Headder Info\ - then change Base Offset from or to 0000
or 0001 (Whichever your's isn't)
Then re-open the table and look again... :lol:
Deckside
Post by Deckside »
Excellent that works
foxy44
Post by foxy44 »
hello where I can find xdf for Ecu p8 thanks
Thack
Post by Thack »
So are you guys using 64kb xdf files or 32kb?
