changing in wireframe
bernhard
Post by bernhard » Tue Sep 23, 2014 8:29 am
might be a fine thing, if the point(s) in the wireframe could be changed by using the '+' and '-'
(or arrow up/down....something like this)
for example for one click '+' the value increases 01h.
only with the mouse it is a little bit imprecisely.
and permanent switching between graphic and text-view is .....annoying? :)
or is there a feature, which I stupid guy haven't found yet?
using latest version
with best regards
Bernhard
Post by Mangus » Tue Sep 23, 2014 2:13 pm
Doesn't matter what view you're in, if you have a cell selected (even if selected via the graph), you can increment/decrement using the numpad +/- or Ctrl +/Ctrl -.
You can assign the keys to whatever you want in preferences.
bernhard
Post by bernhard » Tue Sep 23, 2014 10:48 pm
I just 'retrained' the keyboard with tools -> preferences -> keyboard
- and now it works.
there is offered a lot of set-up options; I haven't had a look at it. my mistake, sry.
might be, that the default setting didn't work, because I'm using a german keyboard/driver?
doesn't matter, it works fine now :wink:
with best regards
bernhard
