1g stutterbox
Discuss DSM (Mitsubishi) definitions here
bcclipse
1g stutterbox
Post by bcclipse » Mon Jun 29, 2015 4:59 pm
Im looking for some help setting up my stutterbox. Im running tunerpro and ostrich. Installed a stock bin and xdf and the car took the tune i put into it fine, but the stutter feature wont work. I have the clutch wire cut at the sensor closer to the firewall. I cut the green wire and routed it from the sensor side of the cut and spliced it into pin 104 wire. I opened the stutterbox in the parameter tree and set the rpm i want it to stutter, saved it, then loaded it into the ostrich but still no stutter. Ive searched for a while and cant find anything so any help or suggestions would be much appreciated. Thanks!
