tutorials and walkthrough for downloading edu files and xdf
applefingers
PostPosted: Tue May 03, 2016 7:25 am    Post subject: tutorials and walkthrough for downloading edu files and xdf Reply with quote
is a simple walk through available to show how to go about how to go about downloading an ecu file from an edu and how to convert and edit it to an xdf file ?
Back to top
Olaf
PostPosted: Tue May 03, 2016 11:24 am    Post subject: Reply with quote
There are several separate process involved. The ability to Read the programming from the ECU / ECM / PCM is one. The ability to Write the programming into the ECU is another. The ability to Edit the programming from the ECU is yet another.
The first step is to Read the programming from the ECU, and then save it as a binary (*.bin) file. The BIN file that you saved will have a specific operating system. To be able to edit this BIN file, you must also have a corresponding XDF file. An XDF file is a "roadmap" of the parameters within the operating system, that have been discovered, and made editable.
To edit a BIN using TunerPro: Open TunerPro, open the BIN file, and then select (open) the corresponding XDF file. Editable parameters should now appear.
You cannot convert a BIN file into an XDF file - they are different things.
If no one has created an XDF file for your specific operating system, then there is no way to edit it using TunerPro.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
