Data Logging with Jet Chip?
rottweiler68
PostPosted: Fri Jul 14, 2017 5:45 am    Post subject: Data Logging with Jet Chip? Reply with quote
Having nothing but trouble connecting to my 1227165 ECM (actually it's the 8259 direct replacement) and was wondering if there is a different stream file I should be using just to data log since I have a Jet stage 2 chip installed? This is an '89 Iroc 350 and am trying to use the 1227165_6E.adx file. It just will not connect and continuously gives the red flashing data read errors.
I've tried playing with the cables and ports and rest of the ideas i've found so I was curious now if the Jet chip makes a difference?
Thank you!
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
