MINPW Zeros Out
frankenstang
MINPW Zeros Out
Post by frankenstang »
If I change MINPW to ANY other number other than what is already in the BIN it will zero out. The value is permanently 0.00. I’ve put 1 in and I’ve put 100 in and the value is 0.00 after hitting save. Say for T4M0 the stock value is 1.4 when I change it to the injector’s MINPW and hit save it comes back 0.00. If you open the text file that logs the changes will say 1.4 to 0.00 and 0.00 to 0.00 for every time after that you try to change it. Basically it’s broken. Is there a way to fix this?
This is an intentional feature in the XDF, according to its author.
frankenstang
Ok. Thanks
