scanning live data
kitttransam
scanning live data
Post by kitttransam » Fri Jan 12, 2018 9:01 pm
Is anyone having problems scanning live data on tuner pro? I haven't used it in a few months but it worked fine then. but now I'm getting into burning chips so I want to see everything that's happing. My BLM's are reading and so is the dashboard. I go to list to look at data and blank. only difference is that I just burned my own chip and I have a memcal adapter. car seems to run fine. this is on an 89 corvette. 1227165 ECM 6E ARAP. I also put the ALDL spark advance at 00.00 if that makes a difference.
kitttransam
Post by kitttransam » Sun Jan 14, 2018 9:04 am
no responses? well I did an experiment. downloaded an older version on my desktop. pretty sure it could be the software itself. so I took pics. version 5.00.9130 has no numbers in the list. version 5.00.8853.00 has numbers in the list. well I tried to post pics but after I'm done and posted it just shows everything in text.
Post by Mangus » Sun Jan 14, 2018 6:57 pm
Thanks for pinging me about this. I can't reproduce it on the machine I'm now, but will try a few others.
festy
Post by festy » Mon Apr 02, 2018 2:07 pm
Same issue here, I've tried a few different ADX files that have always worked, but getting blank list view (all other views are fine).
One thing I noticed - if you scroll the list up or down quickly, a black/green/red dot briefly appears where the data should be.
I tried removing TunerProSettings.dat but made no difference.
Post by Mangus » Mon Apr 02, 2018 2:12 pm
The blank listview is another known issue, probably with the same underlying cause (bugs in the Microsoft C runtime).
I'll be rolling another build soon in hopes to address this, and I'll post it here for y'all to try ahead of general availability.
RR007
Post by RR007 » Tue May 22, 2018 2:23 pm
I have same issue, dash works fine, the list doesn't show anything. just upgraded to the 5009130 version.
im using it on 85 Corvette ECM 1226870 160 baud
