Access ABS System?
haze5736
Access ABS System?
Post by haze5736 » Sat Dec 29, 2018 5:21 am
Is it possible to access the ABS system using TunerPro? I would like to be able to see data from the wheel speed sensors and the ABS valves and solenoids. I'm working on a 1994 Cadillac DeVille with the 4.9L L26 engine.
Post by dex » Wed Jan 02, 2019 5:10 am
If the ABS is using the common OBD-I 8192 baud datastream from a SXR chip then you should be able to datalog it. I think robertsaar posted a list (or a link to a list) of ABS .ads files a while back but I cannot remember for sure.
