DOWNLOADING BIN FILES
shaneh
Post by shaneh » Wed Jan 16, 2019 9:11 am
hi im new to tuner pro, i have dowloaded tuner pro rt and using window vista.
im have trouble importing the bin and xdf files i need ($8d) ive downloaded it and saved to a file but it wont import it, any help would be appreciated
Re: DOWNLOADING BIN FILES
Post by Mangus » Wed Jan 16, 2019 9:28 am
After downloading, make sure the file extension matches what you expect, and not (for instance) .html. If you downloaded an XDF, make sure the file extension is .xdf. If you downloaded an ADS, change it to ADS. Then drag and drop the file into TunerPro.
shaneh
Post by shaneh » Wed Jan 16, 2019 10:38 am
ok thankyou ill give that a go and see how i get on if i can work out how to do that
shaneh
Post by shaneh » Wed Jan 16, 2019 11:40 am
still no luck changed file extensions and drag and dropped them but in, but still cant import them
Post by Mangus » Wed Jan 16, 2019 12:52 pm
what happens when you drag and drop the individual bin file? what error do you get? Does the title bar show that the bin opened? Then try the XDF. What error?
shaneh
Post by shaneh » Wed Jan 16, 2019 2:05 pm
it dosent come up with any errors and title bar dosent say its open'd, maybe im getting confused with where the files go, on the download page is the bin definiton the bin file or the xdf file? and where does the ads file go?
Post by Mangus » Thu Jan 17, 2019 8:57 am
A bin file is a bin file. A bin definition is an XDF, and an acquisition definition is either an ADS (older format) or ADX (newer format).
shaneh
Post by shaneh » Thu Jan 17, 2019 10:19 am
ok great, where do i find the bin file on the downloads
Rev_Up_Your_Engine
Post by Rev_Up_Your_Engine » Wed Mar 20, 2019 1:36 pm
is there any manual or guide on using tuner pro for new users?
Post by dex » Thu Mar 21, 2019 12:56 am
The TunerPro help file (far right drop down menu) covers most things.
Post by Mangus » Thu Mar 28, 2019 9:36 am
Danny Feyrer
Post by Danny Feyrer » Sun Aug 25, 2019 3:38 pm
Windows Vista Might Be The Problem I thought We needed XP
