Me7.2 XDF and bin (other goodies if yall want them)
zarboz
Post by zarboz » Thu Feb 07, 2019 12:42 pm
I have a XDF for the me7.2 running the m62tub44
the XDF was generated from the WinOLS project floating around for the e53 x5 and cross referenced against a dump of my e39 540i
It's rather extensive you can find the funktionsramen for the me7.2 used in the 540i with some googling
forums wont let me post
Enjoy :D Now My hunt to understand WHAT to tune starts
Me7.2_m62tub44_e53.bin.zip
(23.87 KiB) Downloaded 47 times
Me7.2_m62tub44_e53.xdf.zip
(124.83 KiB) Downloaded 50 times
zarboz
Re: Me7.2 XDF and bin (other goodies if yall want them)
Post by zarboz » Thu Feb 07, 2019 6:36 pm
https://github.com/zarboz/BMW-XDFs
Also a collection of BMW Xdfs make sure to clone recursive as I have added other gits that are maintained by other folks
some Damos files and A2L files
zarboz
Post by zarboz » Fri Feb 08, 2019 9:01 am
I have been comparing my 4.4 liter motor file with a 4.6 liter motor file with Dinan tune applied
I have found differences in these tables:
UBDCAN->UBatt threshold for diagnosis CAN timeout
ZLUTSFI->Time constant for filtering uneven running test size
TLAED->Waiting time for detection condition 'driving cycle'
MDNORM->Maximum indexed engine torque for torque normalization
TKATSAN->Catalyst temperature threshold for fuel cut f (nmot)
CWMDKOG->Codeword MDKOG: Ignition angle retardation at negative pressure limitation
DMRKHO->upper Hytereseschrieg Katheiz torque reserve with ZW intervention
DMRKHU->Lower Hytereseschrieg Katheiz torque reserve with ZW intervention
NKUPZWEO->Upper speed Hyteresis threshold for KUP-ZW interventions
NKUPZWEU->Lower speed Hyteresis threshold for KUP-ZW interventions
NLLZWEO->Upper speed Hyteresis threshold for LL-ZW interventions
NLLZWEU->Lower speed Hyteresis threshold for LL-ZW interventions
ETADZW->ZW efficiency as a function of delta ZW
ETALAM->Lambda efficiency
KFZWOP->optimal ignition angle
KFZWOP2->?optimal ignition angle variant 2
NMAXPG->gear-dependent P element in NMAX control
NMXDAEF->Maximum speed for throttle drive replacement function
TNMXPRG->gear-dependent speed prediction horizon for NMAX control
ZINMAXG->gear-dependent I-slope for NMAX control
RLMNN->Characteristic minimum filling
RLMNSAN->Characteristic minimum filling in thrust
ZETABASN->Low pass filter time constant for etabas_w
DZWETA->Delta ignition angle from efficiency
I am still digging and translating will update this post later
zarboz
Post by zarboz » Mon Apr 29, 2019 6:42 am
Github heavily updated
I have been playing with my 540i and got great results I only have a functionsheet for the ME7.3 and ME7.1 (not for the ME7.2) so some items still need deciphering before they are added to the XDF
