Dual wideband connection
Ghwallice
Post by Ghwallice »
Is there an easy, and cheap, way to connect 2 wide band sensors to tunerpro rt?
I'm a novice, and Im fitting 2 sensors to the headers of a twin cylinder motorcycle with a WM16m. Tunerpro rt to a lonelec fiat adaptor, and an ostrich 2 to emulate the 27c512 chip.
I have a single channel innovate, but i'd rather monitor both cylinders. I looked at the Oates post, that doesn't look easy....
Thanks, Greg
Zigmund
Re: Dual wideband connection
Post by Zigmund »
Hi! I think you can use Zeitronix ZT-2 + ZT-3 for dual wideband data logging. ZT-3 has wideband output which could be connected to ZT-2 analog input. I haven't tried this config, but i think it could work out.
