Knock count for 0D Mask
Locked
daveinet
Post by daveinet » Fri Apr 11, 2008 7:43 pm
Does anyone have the packet offset for the knock counter for the 0D mask. This is a 16197427 ECM. Apparently this data is missing from the bin def for TunerPro, which means I can't get this info with ScannerPro either. TTS will give me a knock count, so I assume it exists, but it is missing from the bin def for TunerPro or ScannerPro.
Dave
honken
Post by honken » Mon Apr 14, 2008 10:01 am
Tunerpro rt
Byts number :56
Item size : 8bit
Operatiobn : multiply
Faktor :0.175781
Offset :0.00000
Unit label :degrees
daveinet
Post by daveinet » Fri Apr 18, 2008 5:06 pm
Thanks, I've programed it, hopefully I'll have a chance to see if it works tomorrow.
Dave
daveinet
Post by daveinet » Tue Apr 22, 2008 3:22 pm
Well, I tried it, but something is not right. It does not ever increment the count. One other weird thing is that the knock retard never shows either. I assume that there is knock on occasion as TTS will show a count as well as show an amount of retard anytime I accelerate.
Dave
honken
Post by honken » Wed Apr 23, 2008 9:08 am
Look in your inbox.
Myles57
Post by Myles57 » Mon Aug 09, 2010 4:17 pm
I'm running the same... 16197427 ECM
Did you get the knock count to work? How? I'm new at this... How do I "program" the OD mask as you indicated? Thx
daveinet
Post by daveinet » Tue Aug 10, 2010 8:46 am
$0E instead of $0D. Had the wrong Mask. Honken sent me a defintion that was closer than what I had, but I later discovered I had the wrong mask. Once I used the correct mask, everything works. It may be a while before i can give a specific answer. My computer blew the hard drive and I have as of yet to get TP back installed again.
Dave
Locked
