Win10 tunerproRT no ad connection
Tinker
Post by Tinker »
Ok so win10 tunerproRT have had test bench running with delco 082 and $12p V6 3800 buick .Had system working and DA logging everything as it should be . But after trying to emulate CAS and failing no more DA connecting . I didnt have any smoke nothing like that but seem odd that DA connection doesnt work after trying CAS interface. I dont know if my laptop is damaged or its a autoprom or a tunerpro issue. Uploading bin an reading bin seem to work ok. Not sure what to do . Any ideas
Tinker
Re: Win10 tunerproRT no ad connection
Post by Tinker »
OK, So what i have found is that i can't have my arduino UNO installed (atmeg drivers) and my tunerpro/autoprom ftdi drivers at the same time. After removing the uno drivers and ide my data logging with tunerpro works as it should .
This is a pain because i need to use both on the same laptop. Has anyone else had this problem and what was the fix ?
Tinker
Post by Tinker »
Now i cant get d/a logging at all . have tried reinstalling tunerpro and usb drivers still no luck. Im out of ideas..... :cry:
